Teacher Showcase, David Woods
Mountain Ash Comprehensive
Your variation on the Primer kit is interesting with smaller connectors. It would be worth checking your installation of Creo was configured properly. You default units should be mm KG and seconds with drawings conforming to BS8888. Installation instructions explain how to configure Creo. Email me if you need a copy. -
Many thanks, will have to have a play with it. Might have to ask you for the instructions, but will see how I get on.
