Template mmns_part_solid is missing
vdylan
Hello
I recently downloaded PTC Creo Parametric for my Homework and eduction plan as an industrial engineer. In class we are used to deselect the "Default Template" and select "mmns_part_solid' as template. But there the problem occurs. I only have three templates to chose and neither of them is the good one.
Is there a solution for it?
Thanks for helping
Dylan
Dylan,
You can take one of the part templates you are seeing and save it as "mmns_part_solid.prt" in whatever directory your template files exist in.  Change your units as follows (going by memory but I think these would be correct):
Length: mm
Mass: gram
Force: N
Time: sec
Temperature: C
Since you saved it in your directory using the student version of the software the new template file will be usable going forward.  I tell my students the same thing when they run into something like this with the student version of Creo.
Hope that helps!
Mike
Dylan,
Length: mm
Mass: gram
Force: N
Time: sec
Temperature: C
Hope that helps!
Mike
