Hi guys,
I would like to know about how to add a texture to an object (wood) I know how to add color, but I would like a texture.
Thanks.
In short, when you create a new appearance (color) you can go the the Map tab and add a Bump file to it. You can Google and find bump map files.
Here are the instructions from Help:
Is this on wildfire 5?
Wildfire 5, Creo Elements/Pro and very similar in Creo Parametric 1 & 2.
