Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
The first cd zip fails to download. Its downloaded immediatly but containts no files. What can I do or is it up to you? With the second CD I have no problems.
