Trail Files
tfilipiak
Trail Files
I want to learn how to use Trail files and have been wasting hours trying to find out how.  I also would like some stable trail files that I can use to demo them in classes.  I have search in Creo help, in the PTC Community, online on various sites.  I've played around with it.  Nothing seems to work the way I expect it too.
Please someone save me from wasting more time on this.
I tried doing the "Play Trail File" and it doesn't work.  The trail file always exits the software.
- How to edit trail files?
- How to play trail files?
- How to ensure that the trail file stops before exiting the Creo Parametric so I show what the file did?
etc.
Nothing is ever easy with PTC and Creo.  Ever.
  • use Notepad
  • use "Play Trail File" command
  • last command written in trail file is ... File > Exit
  • suggestion ... use Date&Time command to put a mark into trail file and then exit session ... then open trail file in Notepad, go to to end end remove lines located after date&time information
Martin Hanák
