I was having problems with 2.0: http://communities.ptc.com/message/260223#260223 so i saw 3.0 in the academic area as downloadable, now it says license doesn't work. I used the same license I got in the mail for 2.0.
I am falling behind without please ASAP
Sam,
Have you submitted a support request yet? That will help us get you up and running quicker. The link is located below...
http://support.ptc.com/appserver/wcms/forms/index.jsp?&im_dbkey=142574&icg_dbkey=482
Please let me know if you have any questions!
There's an updated page to obtain a license for Creo 3.0 however I'm getting errors for the install on the Simple license Entry section.
I didn't see that, the link please? Do you know what else we could do if that doesn't work?
Here's the link. http://www.ptc.com/communities/academic-program/products/free-software
Apply for the new license and once you recieve the email of the license save it to C: Program Data/PTC/Licensing,
Then once you run the installer, drag and drop the file into the Available licensing area and then Creo should run.
Sam,
