I am trying to dowmload the student version creo 2.0 but due to internet breakdown and load shedding it always ends up with a network error. Is there any other ay to downlaod the software? perhaps updating a torrent link to the website?
Abdullah,
In some cases trying the other type of download (HTTP in your case) sometimes works. Unfortuantly that is all the advice I can give you as I am unable to help you with your internet connection.
Abdullah,
Unfortuantly there is not any way for me to do that for you. Could you perhaps try downloading Creo on another network? Also are you using HTTP download or the download manager?
I used the download manager.
Abdullah,
thankyou for your help, I was able to download the software but unfortunately I no longer have access to that laptop. Can I install the software on another laptop using the same product code ? I did not uninstall the software from the previous laptop.
Abdullah,
As long as it is the student edition, you can use that product code on as many computers as you would like!
