I am able to select the edges to give a dimension, but it's not working. I am not sure if I missed something. Can someone please help me out here?
@Madhava wrote:
Hi, thanks for the reply.Please watch the attached clip and let me know what you think....
use following steps:
Please specify which version of the program you are using.
please record a video showing your attempts and attach it to next reply.
No clip available.
please use computer application to record video, for example Screencast-O-Matic. Application enables you to get better video quality.
Thank you very much, I am able to give a dimension now.
