Unable to reinstall Creo after system format.
ptc-1059728
3-Visitor
I have a perpetual license of Creo 3.
I have installed Creo several times in the past. But recently I have formated my laptop with the OS I am using previously, Windows 10. During installation even it is not detecting the network card. I have tried disabling firewall. But still it is same issue mention in this thread.
open Command prompt window and run ipconfig /all command. The output of command shows network card. Check whether HOST-ID included in license file is present in the output.
Note: If you own floating license, you have to install FLEXnet license manager before you install Creo.
Martin Hanák
I did the said checks before installing. Find attached.
Also let me know how to install install FLEXnet license manager before I install Creo.
Thanks for stopping by.
The above output is telling you that D-Link Wireless adapter is turned off.
Connect to network using D-Link Wireless adapter. This way you turn it on and Creo will find it.
The above picture does not tell me whether your license is locked/floating.
If your license file contains SERVER and DAEMON lines (see below example) then your license is floating. In other case your license is locked.
SERVER __HOSTNAME__ PTC_HOSTID=00-24-01-14-49-D1 7788
DAEMON ptc_d __PTCD_PATH__
Martin Hanák
Thank you for the quick responce.
Find attached
Find attached
your license is floating you must install FLEXnet. Run setup.exe and use Setup license option (hopefully it will work).
Installer creates C:\Program Files\PTC\FLEXnet Admin License Server directory and system service lmadmin_ptc.
You can run C:\Program Files\PTC\FLEXnet Admin License Server\bin\ptcstatus.bat to verify whether license is available.
During Creo installation you enter  7788@YourComputerName as license source (do not specify license file as license source).
Martin Hanák
