After installing the PTC CREO student version on my laptop i'm unable to see the part and/or datums on the model window. The part opens correctly but nothing shows on the screen. How can i fix it? Is a installation issue?
All datums are turned on, no part is hidden. I just cant see anything, just a blank model window where a part is supposed to be showing.
Hi Ramon,
This is usually related to a graphics-driver related issue. I would recommend trying the following guide:
http://apps.ptc.com/schools/references/support_creo2_graphics.pdf
Please let me know if you are still experiencing an issue!
Hi Ramon,
