Update PTC Creo license for another year
imerideñolabaye
My students worked during the last year with PTC Creo Parametric Student Edition, versions 3.0 and 4.0. They used the licenses provided in this forum:
  1. For Creo 3.0: BE400407EDSTUDENTEDK12
  2. For Creo 4.0: BE410708EDSTUDENTEDK12
However, I am afraid this licenses will expire soon. Is there a way of just updating the license without having to uninstall and install again the program.
Thank you in advance.
It worked! Thank you very much!
4 REPLIES 4
try a procedure described in attached PDF file. It is related to Creo 3.0. I hope you can apply similar procedure for Creo 4.0.
Martin Hanák
Thank you for your response. I will try it and see if it works.
However, does the license code change every year? Or is it always the same? I thought it was a different number every year.
Thank you!
Thank you!
Product code value remains the same.
The contents of licence file is changed.
Martin Hanák
