My students worked during the last year with PTC Creo Parametric Student Edition, versions 3.0 and 4.0. They used the licenses provided in this forum:
However, I am afraid this licenses will expire soon. Is there a way of just updating the license without having to uninstall and install again the program.
Thank you in advance.
try a procedure described in attached PDF file. It is related to Creo 3.0. I hope you can apply similar procedure for Creo 4.0.
Thank you for your response. I will try it and see if it works.
However, does the license code change every year? Or is it always the same? I thought it was a different number every year.
Thank you!
Thank you!
Product code value remains the same.
The contents of licence file is changed.
It worked! Thank you very much!
