Hi Dave, The easiest way to find the latest document or modified work....is to click the Last modified Column header. This will sort the folder content to the latest files. I use this often. Alternatively, you can also click the VIEW pull-down filter and choose to view LAST MODIFIED. This will order the content into modified order. I would choose the first option, as it will also show the folders as well. Hope that helps. Mark
