I am having problems with using variable section sweep. Perhaps I am not understanding the purpose of this tool. Is it not the same as a regular sweep with different cross sections? When I try the variable section, I can't seem to draw more than one section, therefore it is only a constant section sweep. I can place the section along the path at different points, but I can't see any way to create more than one section at a time. Help!
