Hi could someone share the link to this page please?
For some reason mine has disappeared. I am referring the the web form I fill in to get a standalone Academic Premium license for Creo3.
In ALL of our schools, due to WAN security of networks, the usual 'on line' licensing cannot work due to port blocking.
thanks
PeterT
Hi Peter,
The PTC web site seems to be having prolems at the moment. Below is a copied post from Mark Cheli for web page licensing.
Cheers
Tim
"The link that he is referring to can be found here assuming you are using the Creo 3.0 Schools edition standalone license: http://www.ptc.com/appserver/lm/programs/index.jsp?&hostid=REQUIRED&program=creoedusgl3&product=BH400407EDSTUDENTEDK12
Once you have the file, save it to C:\ProgramData\PTC\Licensing and restart the install. Your license should show up in license summary and allow you to go to the next step of installation."
Hi Peter,
Cheers
Tim
Thanks Tim, saved me some time!
I just forgot it still says Creo 2! I could fix that for them with an appropriate log in.
Pointed out when 3.0 was first released... Ha! ![]()
