I want to avoid saying... Inventor did this, but how do you do it in Creo? However...
Inventor allowed us to setup a project folder on a network drive and associated a library of parts with the folder allowing more than one student to work with the folder at a time. Is there an equivalent using PTC Creo.
Also... Can someone recommend a structure... or a phillosphy on how to get started. Meaning... I've always tought my students a basic configuration and a folder structure to setup before anything is drawn.
Any recommendations?
Hi Frank,
Creo allows multiple settings for working directories, libraries, start parts, etc. These can all be set in the Options menu. You can set up a shared Google drive, network drive or whatever.
My personal suggestion would be to use Windchill. This allows versioning and locking of files. Keeps people from stepping on each other's toes and is a common storage method for big companies. You can register and find more information here http://www.ptc.com/communities/academic-program/k12/students/first/windchill-registration
Hi Frank,
