I am a high school student and my robotics team is using Creo to build our CAD-version robot. I've had two laptops from Catepillar and each one has worked for a bit, then will, for no reason, stop working. I can log on to the server, but then I can't pull up my workspace or the team's cabinets. The browser on load to the point in the picture, then not load any further.
![2013_12_19_19_42_54_Creo_Parametric_Student_Edition[1].png](https://community.ptc.com/legacyfs/online/64982_2013_12_19_19_42_54_Creo_Parametric_Student_Edition%5B1%5D.png)
Note: I did try to downgrade to IE 10, but that hasn't fixed the problem.
Hey Jairus - welcome to PTC Community!
I've moved this discussion into our Academic Support forums so that the team there can help you troubleshoot this issue.
Cheers,
- Ryan
