arduino not connect with thingworx
eesquivel
Hi I have a problem, I have connected 1 temperature sensor to an Arduino card and I want the data to be recorded in a thing, the connection is made but in the properties there is no value, attached screenshot to see if I can support
#include <Wire.h>
#include <DHT.h>
#include <SPI.h>
#include <Ethernet.h>
//How many values you will be pushing to ThingWorx
#define propertyCount 2
#define DHTPIN 2     // what digital pin we're connected to
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
IPAddress ip(192,168,20,35);
char server[] = "3thmsdws.pp.vuforia.io";
int port = 443;
EthernetClient client;
//ThingWorx App key which replaces login credentials)
char appKey[] = "4d6fc02c-bf77-4da7-98db-e115c3771fcd";
// ThingWorx Thing name for which you want to set properties values
char thingName[] = "HTD22ThingPrueba";
//Interval of time at which you want the properties values to be sent to TWX server
int timeBetweenRefresh = 5000;
// ThingWorx service that will set values for the properties you need
// See the documentation for this tutorial for more information
char serviceName[] = "setTempAndHumid";
//Initialize Properties Names and Values Arrays
char* propertyNames[] = {"Temp", "Humid"};
double propertyValues[propertyCount];
// last time you connected to the server, in milliseconds
unsigned long lastConnectionTime = 0;
// state of the connection last time through the main loop
boolean lastConnected = false;
//Initialize an HTU21D library object to read
// temperature and humidity data from your connected sensor
DHT dht(DHTPIN, DHTTYPE);
void setup() {
  //shut down the SD Card pins
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  // start serial port:
  Serial.begin(9600);
  Serial.println("Temperatura y Humedad con Arduino");
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  //initialize HTU21D object to read values from sensors
  dht.begin();
  // start the Ethernet connection:
  //Serial.println("Trying to get an IP address using DHCP");
  Ethernet.begin(mac, ip);
  Serial.print("My IP address: ");
  Serial.print(Ethernet.localIP());
  Serial.println();
void loop() {
// Aquire sensor values
   propertyValues[0] = dht.readTemperature();
   propertyValues[1] = dht.readHumidity();
  // Wait a few seconds between measurements.
  delay(5000);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  // Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print(" *C ");
  Serial.print(f);
  Serial.print(" *F\t");
  Serial.print("Heat index: ");
  Serial.print(hic);
  Serial.print(hif);
  Serial.println(" *F");
if (millis() - lastConnectionTime > timeBetweenRefresh) {
    updateValues(propertyValues, client, server, appKey, thingName, serviceName, propertyNames);
void updateValues(double values[] , EthernetClient &client, char server[], char appKey[], char thingName[], char serviceName[], char* sensorNames[])
  //build the String with the data that you will send
  //through REST calls to your TWX server
  char data[80];
  strcpy(data, "?appKey=");
  strcat(data, appKey);
  strcat(data, "&method=post&x-thingworx-session=true");
  // if you get a connection, report back via serial:
  if (client.connect(server, 443)) {
    Serial.println("connected");
    // send the HTTP POST request:
    client.print("POST /Thingworx/Things/");
    client.print(thingName);
    client.print("/Services/");
    client.print(serviceName);
    client.print(data);
    client.print("<");
    for (int idx = 0; idx < propertyCount; idx++)
      client.print("&");
      client.print(propertyNames[idx]);
      client.print("=");
      client.print(propertyValues[idx]);
    client.print(">");
    client.println(" HTTP/1.1");
    client.print("Host: ");
    client.println(server);
    client.println("Content-Type: text/html");
    client.println();
     client.stop();
    lastConnectionTime = millis();
    // print the request out
    Serial.print("POST /Thingworx/Things/");
    Serial.print(thingName);
    Serial.print("/Services/");
    Serial.print(serviceName);
    Serial.print(data);
    Serial.print("<");
      Serial.print("&");
      Serial.print(propertyNames[idx]);
      Serial.print("=");
      Serial.print(propertyValues[idx]);
    Serial.print(">");
    Serial.println(" HTTP/1.1");
    Serial.print("Host: ");
    Serial.println(server);
    Serial.println("Content-Type: text/html");
    Serial.println();
  else {
    // If you didn't get a connection to the server:
    Serial.println("the connection could not be established");
    client.stop();
1 REPLY 1
posipova
20-Turquoise
(To:eesquivel)
Have you checked this guide?
Weather App with Arduino Uno
