code using nurbs in ptc creo3.0
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hi everyone! Im using ptc creo 3.0 im a student and i need some help please. I need an integrated code in Visual Basic that shows that ptc creo using nurbs method in programme interface. I appreciate your help . Thank you very much for your time.. Please gime me some knowlege.. i need it for my exercise in my college.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Please anyone any example from code like cylinder,sphere or cone... its important please for my exercise.. thnk you!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi again! Its important to me if someone have a code for example in VB. I appreciate a lot. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
We struggle enough to learn to -use- the system where reverse engineering it is of little use to anyone.
Have you tried approaching PTC engineering with your question so you can get it straight from the developers?
The only feature I think will show this is the Warp feature. But none of us has access to the underlying code.
Why is this so important?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I do my dissertation and i must found some simple codes in VB to show that creo use Nurbs... Thats why is so important for me.. and i search how to have access to api environment. Thank you Antonius Dirriwachter .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I think the VB API does not include the ability to create geometry. You need to have access to Toolkit.
If you are interested in working with NURBS then you might try Blender: http://wiki.blender.org/index.php/Doc:2.6/Manual/Modeling/Surfaces
Alternatively, as found using https://www.google.com/?gws_rd=ssl#q=programming+nurbs
OpenGL http://www.glprogramming.com/red/chapter12.html
"The NURBS Book" http://www.amazon.com/dp/3540615458/?tag=stackoverfl08-20
and many others.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Yes, a colleague confirmed that you can read out geometry information (e.g. ipfcSurface.GetNURBSRepresentation), but not create geometry in VB.
The theory behind geometry definition in Creo can be found in the VB API User's Guide in the last section (Geometry Representations).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Software engineering is the study and an application of engineering to the design, development, and maintenance of software
_____________________
FARASAT
