I am getting an error mesage that the file is either corrupt or invalid when I trying to extract the files from the downloaded zip file of Creo version 2. I am using Windows XP and the downloaded file size is 4.2 Gb.
Hi Michael,
This is a relatively common issue, and here are the most common reasons why this can happen...
Another common solution that a lot of people will do is to download the DVD on another computer that is preferably on another network. Once the download finished, use the other computer to extract the files and then use a flash drive to move the folder back. This will bypass all three of the above problems and if it is an option for you, will probably be easiest.
Please let me know if the problem persists! Thanks!
Hi Michael,
