Hi, I have installed creo 5.0 Student Version according to the description on an Windows 7 Lenovo W540 (and optionally also on a Windows10 Gaming PC) and finished the installation successful. (both with and without Firewall)
When I try to start, the program don't start at all. No message, no window, nothing. What can be the reason for this issue?
i am facing the same problem.
Hi I have the same problem. Did you find a solution to it?
I am facing the same problem. If any found the solution, please let me know
Please submit a support request here: http://support.ptc.com/appserver/support/academic_case_logger/academic_case_logger.jsp
Hi, I have the same Problem but whit CREO 7.0 . How could I this Problem solve. In your link the Problem Matcher goes up only until CREO 6.0
Hey, did you try reinstalling your graphics driver?. I had issue in opening the application and sometimes it turns out to be your graphics driver. let know if that solved your problem
how do I do that? doesn't hapens automatically?
Well, if you are using windows, for any update, it reinstalls the drivers and sometimes, it doesnt install properly. Or your driver might need an update. I recommend doing it manually if such problems arises. See if your other similar software is opening or not, if not that would be the case. If only creo is not starting, then there might be installation issues of creo , so you have to uninstall, clear all files and install fresh. Cheers
