creo 7 missing shortcut
YE_9816325
7-Bedrock
everytime i try to open creo parametric or simulate it keeps saying there is a problem with the shortcut and asks me to locate the file every time, and when i click fix it, it does not do so.
I fixed it by clicking the properties from the shortcut and locating the file manually. My main issue was finding the launchable application from the files as for some reason creo parametric, simulate etc were all in the bins section  of their individual file which I found weird, but I fixed it to the correct path and it works now.
5 REPLIES 5
Does this tip help you? "Unable to launch Creo Trial from the PTC Creo Player Icon": https://community.ptc.com/t5/PTC-Education-Forum/Unable-to-launch-Creo-Trial-from-the-PTC-Creo-Player-Icon/m-p/732329#M12116
open Properties of shortcut and check whether it contains correct information. Saving shortcut properties needs admin rights.
Note: You can copy shortcut into your personal directory (where you have full access rights), modify copy properties a use it to start Creo.
Martin Hanák
When I click properties this is what is says for my target: "F:\Creo 7.0.2.0\Parametric\bin\parametric.exe"
open File Explorer and browse to F:\Creo 7.0.2.0\Parametric\bin directory. Does it contain parametric.exe file ?
Martin Hanák
