I can't download the PTC Creo 2.0 Student version. If I click on the download manager, than it doesn't open the manager, but start downloading from https. The main problem is, when it's done and try to extract the file, it shows hundreds of CRC Errors.
Please help me as soon as possible.
Hi Veronika,
All seems to function as it should on our end here at PTC. Have you given it another try? We just recently released Creo 3.0 so our servers are under a little bit more load then usual.
Hi Veronika,
Thanks for your answer!!
I tried it again, and fortunately it works!
I'm so happy. ![]()
