dysfunctional placement button
akožienka
I have problem with placement button in component placemnet . When I do assembly and I want change placement so, placement button don t work. I have creo3 with new student license because I had to recover old. In old version it worked good but in new not. So what I should do ? Thanks for all answer.
1.] info for you
%APPDATA% variable contains path to C:\Users\username\AppData\Roaming directory
%LOCALAPPDATA% variable contains path to C:\Users\username\AppData\Local directory
Therefore I asked you to delete PTC subdirectory in C:\Users\username\AppData\Roaming directory.
2.] Creo Parametric 3.0 enables user to unpin dialog box from its tab (user can move dialog box to any screen location). I guess that you did such action and then saved customization file (creo_parametric_customization.ui). Maybe you moved dialog box to second monitor and forget about it ...
I did some testing and realized that "unpinned" status is saved in customization file (creo_parametric_customization.ui). So find this file (with .ui extension) and rename it (for example to creo_parametric_customization.ui.xxx).
The file can be saved:
  • in your working directory
  • in C:\Users\username\AppData\Roaming\PTC\ProENGINEER\Wildfire\.wf\.Settingsdirectory
  • in CREO3_LOADPOINT\Creo 3.0\M060\Common Files\text directory
MH
Martin Hanák
you can try following:
  • open Windows Explorer and go to %APPDATA% directory
  • delete PTC subdirectory
MH
Martin Hanák
Hi
Thank you for your answer. I tried to use your advice but it didn t work. It s possible that I did it wrong, because I have in APPDATA two directory 1. LOCAL with PTC  2.ROAMING with PTC . So I don t know which one delete
1.] info for you
MH
Martin Hanák
Today I switched on creo and creo is working good. Thank you for your advice.
Hi MartinHanak,
I had the same problem and I did as you said.
Now the placement button works fine.
Thanks a lot for your help.
Best regards.
