error message when trying to install license for student edition
cknowles
i get a simple message saying error underneath the box when trying to install license for student edition
Hey there Oliver,
I just figured this issue out on my own account- I think I had the same problem as you do.
If it is the same, I'm guessing you copied and pasted your activation code to avoid error.  That's what I did.
Turns out, manually entering the code instead seemed to fix it.
Give that a try, hope it works for ya!
Hey Bradley,
Having the same problem and tried your way. dint work for me. Any other suggestions?
ChrisCarr
(To:cknowles)
Hi Callum,
If you hover your cursor over the "Error", it should give you more information. What does it say?
Chris
