error opening creo parametric 3
ded
3-Newcomer
3-Newcomer
I'm a student and i had to change pc, so i downloaded creofor student for the second time in this new pc. I have a problem and i can't understand how to solve it. Could you help please?
I have this error...
ps: in the previous pc it works without problem.Cattura.PNG
6 REPLIES 6
BenLoosli
(To:ded)
Did you obtain a new license file for the new computer, if using a standalone version.
If using a network license from your school, see your administrator.
ded
3-Newcomer
3-Newcomer
(To:BenLoosli)
It is a stand alone version and firstly i tried with the same license but, obviusly, it didn't work so i obtain a new license with the account of my sister(also a student) but I get that error message.I tried to unistall and reinstal creo but it persist. The setup program check the license correctly, could you suggest some other solution? Thanks a lot for helping
BenLoosli
(To:ded)
When you requested the new license, did you specify the NIC address of your new computer? That is what controls the access.
MartinHanak
(To:ded)
error message is telling you that C:\Program Files\PTC\Creo 3.0\M110\Parametric\bin\parametric.exe file does not exist.
Martin Hanák
ded
3-Newcomer
3-Newcomer
(To:MartinHanak)
So the problem is that the setup didn't work correctly? May i solve downloading the fourth version?
MartinHanak
(To:ded)
unfortunately I do not know what is going on on your PC. Try whatever you want 🙂
Martin Hanák
