error while installation
SS_9630153
3-Visitor
After installing creo 5.0 this is showing license requesting failed for feature. tell me what to do........
HI SS_9630153,
I believe you are trying to use the product code valid for creo parametric academic version 4.0 with 5.0.
Please use product code BE500806EDSTUDENTEDK12 to work with Creo Parametric 5.0
To have detailed information please click here
Vipul
8 REPLIES 8
you must reconcile the contents of the parametric.psf file with the license file located in C:\ProgramData\PTC\Licensing directory.
Please upload these files, if you want additional help.
Martin Hanák
In parametric.psf where should i looks for the  C:\ProgramData\PTC\Licensing directory.
Steve.
Hi @SS_9630153,
Open the parametric.psf in notepad and look for the entry shown below
Also, make sure your license file is located in default location as mentioned.
Vipul
I made the changes as you suggested but when opening creo it is giving the error message attached.
I need to get this thing running as i have my school project to complete.
suggest me on this
Steve.
HI SS_9630153,
Vipul
Hi
I got your point now. my bad
thank you for providing the PDF following the instructions Creo is working fine.
thanks
Steve
suggest me on this
Steve.
Product code BE400407EDSTUDENTEDK12 is related to Creo 3.0. You cannot use BE400407EDSTUDENTEDK12_license.dat to launch Creo 5.0.
Do not forget to remove all files from C:\ProgramData\PTC\Licensing directory, before you install Creo 5.0 with product code BE500806EDSTUDENTEDK12 !!!
Martin Hanák
i followed the exact procedure in PDF also you mentioned and creo is working fine
thank you
Steve
