Buen día, comunidad. Tengo un problema al extraer los valores pares e impares de un vector en orden. ¿Existe alguna función para realizar esta operación?.
Just stumbled over this thread.
For whatever it may be worth, here is a different way to skin this cat:
The functions can deal with matrices with more than 1 column and works OK with any value you set for ORIGIN. But if ORIGIN is set to an even number like 0 or 2, the first returned matrix contains the rows with even row index (even though I called it "odd". 🙂
BTW, for questions about the usage of Mathcad or Prime you are better off and might get more attention if you post in the Mathcad forum.
Prime 10 file attached
