fatal error encountered
VB_10233158
2-Explorer
How to solve this problem in Creo Parametric 8.0.4.0
please describe a situation causing the crash.
Martin Hanák
remy
(To:VB_10233158)
This means Creo crashed.
PTC Tech Support walks you in troubleshooting Creo with the holistic tool Creo Stability Troubleshooter : https://www.ptc.com/en/support/creo-stability-troubleshooter
Or else you can file a Support case.
If the latter attach, the model, the traceback.log file. TSEs will be able to analyse the log and compare it to our crash signature database.
MartinHanak
(To:remy)
FYI ... students cannot contact PTC Support.
Martin Hanák
