I just changed the student version to the pro version but when i tried to opned a file created in the student version i got :
the file .... was created with an educational version and is not compatible with the version that the host is running
Can someone help me please? , i need the file i created before , is there a way i could convert to the student edition and viceversa?
You could try saving as an IGES file in Academic and then opening this in Professional.
Bob Booth
but could i save a file in the professional and then open it in the academic?
Initial Graphics Exchange Specification (IGES). I would think so. I've brought old ProDESKTOP files into Creo2. You may not have full access to all the build commands for modification but image and assembly should be faithful.
