The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
i logged on CREO parametric and i recived a email from schools@ptc.com with PTC license pack as attached.
I setuped setup-school.exe and i downloaded PTC applications but i couldn’t log-in in this step.
when i run CREOparametric 5.0 an error message appears, please find attached. Could you please help me? Thank you.
The license is valid for Creo 5.0 and should run properly.
The reason you see that error is that the Mac Address that was active during installation process is no longer available.
You can try to change the state of the Wireless (try opening Creo with WiFi on, even if it is not connected to any network). If the wireless was used (or any external USB network device) during the licensing process, it will need to stay on for Creo to work.
Alex
it doesn't work
ipconfig /all > ip.tx command doesn't work.
ipconfig /all runs but there is not 0C-5B-8F-27-9A-64
in ip.txt there is not 0C-5B-8F-27-9A-64
1.] open Computer Management window and check physical network card's status. All your network cards must be enabled.
On my PC, 1st card (Ethernet, wired) is enabled, 2nd card (WiFi) is disabled (see small down-arrow in circle)
2.] open Command prompt as Administrator and run following commands
netsh interface ipv4 set global dhcpmediasense=disabled
netsh interface ipv6 set global dhcpmediasense=disabled
3.] restart PC
4.] run ipconfig /all > ip.txt command, again check its contents (also you can upload the file, I can check its contents, too).
1.] DONE see attached
2.] DONE
3.] DONE
4.] ipconfig /all > ip.txt command DO NOT WORK --> i runed ipconfig /all (see attached) and there is 0C-5B-8F-27-9A-64
5.] In ip.txt there is not 0C-5B-8F-27-9A-64
1.] I've never had a problem with ipconfig /all > ip.txt
This command redirects output of ipconfig /all command into ip.txt file located in current directory. In your case it is C:\Users\antonio
2.] I guess the following card is not recognized by Creo properly
3.] My suggestion is ... connect to network via Ethernet or Wireless physical card
1.] you can see in previously file attached ipconfig /all > ip.txt not working
2.] I used Remote NDIS Card to install CREO and in Licensing step.
3.] I tried to run CREO with Wifi on and without Remote NDIS card but CREO crushes.
4.] I received License by e-mail. where i'm supposed to save it? (now it's on desktop)
license file can be saved in any directory. During installation you enter full path to the file.
Unfortunately I do not have any other suggestion how to solve your problem.
i tried to unistall and reinstall and now it doesn't open. it just crushes.
