I have a due project and the language is in Spanish I wish to change it back, help me please.
Add the following line at the end of parametric.psf file, if you want to use English version of Creo:
ENV=PRO_LANG=english
Languages supported:
| Language | Environment Variable Name |
| Chinese Simplified | chs |
| Chinese Traditional | cht |
| French | french |
| German | german |
| Italian | italian |
| Japanese | japanese |
| Korean | korean |
| Spanish | spanish |
| English | C or english |
| Russian | russian |
See also:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS110907
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS147730
MH
| French | french |
| German | german |
| Italian | italian |
| Korean | korean |
| Spanish | spanish |
| Russian | russian |
See also:
MH
