I have a due project and the language is in Spanish I wish to change it back, help me please.
Add the following line at the end of parametric.psf file, if you want to use English version of Creo:
ENV=PRO_LANG=english
Languages supported:
Language | Environment Variable Name |
Chinese Simplified | chs |
Chinese Traditional | cht |
French | french |
German | german |
Italian | italian |
Japanese | japanese |
Korean | korean |
Spanish | spanish |
English | C or english |
Russian | russian |
See also:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS110907
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS147730
MH
French | french |
German | german |
Italian | italian |
Korean | korean |
Spanish | spanish |
Russian | russian |
See also:
MH
