When ever I exit Creo and come back the working directory will revert to its original file location. It doesn't give me a prompt to save it to a config file or anything when i do change it. How do I save the working directory location?
im using creo 8 student edition
edited startup location in properties
also following config.pro option is useful.
file_open_default_folder working_directory
