can anyone help me in the same.
All the PTC CAD KOP and FOP files are available here: Software
Just scroll to the bottom of the page.
Hi Yash,
I think you should start with the K-12 Tech Support team on the PTC website. I would suggest you Submit a Support Request.
Amit
Thank You
I got to the result my searching the site
Thank you again
I was a bit puzzled for the fop
Whenever i connect to internet then i can't use my ptc creo parametric 3.0 WHY?
I have to restart my laptop and then start creo by first disabling the internet so as to work on this awesome software
How were you connected to the internet when you created the license? Possibility of being on an ethernet cable? This might have licensed your software to your LAN NIC and not your Wifi NIC. Just an idea. There should not be any restriction or limitation to running the software based on your internet connectivity.
There is a setting that prevents Windows from disabling the LAN NIC when the WiFi NIC is in use.
Check networking - Disable wireless when ethernet connection is detected on an HP EliteBook - Super User
