license help
nwalters2019
3-Newcomer
license help
I keep getting this. iv tried the regular version and the school version. I'm using the education edition but I keep getting that message above.
BK600908EDSTUDENTEDUNI
Try to run setup.exe as an administrator and add the license that you got on email in the licensing window, under license summary. Then finish the setup and all should work.
Alex
it did not work. Same prompt
So I guess you are installing Creo 6.0, correct?
Also can you try this instruction:
http://apps.ptc.com/schools/references/install_creo6_schools_standard.pdf
Thansk,
Alex
