license renewal Creo10 - "Customer not verified"
LV_10883015
my creo10 university or educational license is about to expire in 5 days.
When I start up Creo on my desktop, I am offered the possibility to renew my license.
When I enter my username and password, I get the message "customer not verified", and there it stops.
I found info online that said I could manually delete the license file etc., but I am a bit reluctant since I do not know if that is the right way forward.
Can you please advise me what to do?
Kind regards,
Lukas Van Campenhout
3 REPLIES 3
Take a look here - "Creo parametric 9.0 student edition Licence renewal error": https://community.ptc.com/t5/PTC-Education-Forum/Creo-parametric-9-0-student-edition-Licence-renewal-error/td-p/923003
LV_10883015
(To:VladimirN)
Dear Vladimir,
thank your for your tip. I renewed my password, but that did not help.
I deleted the license file  in C:\ProgramData\PTC\Licensing, and copied it to directory Creo10_License.
Then, I installed Creo11, including the new license. The license installation was successful. The installation of CREO11 seemed to go well.
However, Creo11 did not start. I received the following message (see also attached content)
Then I had the idea to start up Creo10 again. To my surprise, it worked, without the message that the license would expire.
I also got an email with a .dat file. It contains the license data for CREO10. It tells that the new license will be available until 1 December 2025.
So, the renewal of the CREO10 license worked. But now I also have an installed version of CREO11, which does not work.
As long as CREO10 works, I am good. Should I uninstall CREO11? Or leave things as they are?
Kind regards,
Lukas
