my creo10 university or educational license is about to expire in 5 days.
When I start up Creo on my desktop, I am offered the possibility to renew my license.
When I enter my username and password, I get the message "customer not verified", and there it stops.
I found info online that said I could manually delete the license file etc., but I am a bit reluctant since I do not know if that is the right way forward.
Can you please advise me what to do?
Kind regards,
Lukas Van Campenhout
Did you use the following instructions for version 11?
https://apps.ptc.com/schools/references/install_creo11_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo11_unistudent_standard.pdf
Take a look here - "Creo parametric 9.0 student edition Licence renewal error": https://community.ptc.com/t5/PTC-Education-Forum/Creo-parametric-9-0-student-edition-Licence-renewal-error/td-p/923003
Dear Vladimir,
thank your for your tip. I renewed my password, but that did not help.
I deleted the license file in C:\ProgramData\PTC\Licensing, and copied it to directory Creo10_License.
Then, I installed Creo11, including the new license. The license installation was successful. The installation of CREO11 seemed to go well.
However, Creo11 did not start. I received the following message (see also attached content)
Then I had the idea to start up Creo10 again. To my surprise, it worked, without the message that the license would expire.
I also got an email with a .dat file. It contains the license data for CREO10. It tells that the new license will be available until 1 December 2025.
So, the renewal of the CREO10 license worked. But now I also have an installed version of CREO11, which does not work.
As long as CREO10 works, I am good. Should I uninstall CREO11? Or leave things as they are?
Kind regards,
Lukas
