is there a maintenance release for creo student edition 2.0?
1. if yes then how to downoad it?
2. if no, then why not?
You do not specify which release and build you currently have. The latest install DVD image Creo 2 (M030) can be downloaded from http://www.ptc.com/appserver/auth/it/esd/academic.jsp.
A big thank for your prompt reply. current release being used in M010.
