product code creo 12 error and Unsuitable license source
IC_14419828
2-Explorer
I am a student and have an academic product code for Creo Parametric.
However, I am receiving the error message:
"You have reached the maximum number of license applications available for your product type."
I installed and reinstalled Creo several times, and now my product code is blocked.
Could you please reset my license activations so I can install the software again? Otherwise how to do?
Thank you very much.
Your product code: (BK120908EDUNIVERSITYED)
And my license source was automatically set when I could still put the code. Except that it was marked as unsuitable. What to do?
Please contact academicsupport@ptc.com. You need to send them the Host ID (Mac address of the ethernet) and also the product code used. I hope they will send you valid license file.
Host ID ... this means physical address of network card
  • if Ethernet network card is installed in your computer then use its physical address
  • if the only network card is WiFi network card then you must turn off MAC address randomization to get real physical address
Martin Hanák
