Hello Guys, i need some help with the nerve-wracking installation of CREO parametric 4.0.
I've been using it for about 1 year now without any installation problems on my computer and my laptop.
Today I needed to reinstall Windows on my laptop, so I had to do the same with CREO.
At first, I had no problem entering the student license but after I opened Creo I got this error in the picture.
After browsing the forum I think I‘ve tried everything I could do:
I checked my Host-ID:
W-LAN: CC-B0-DA-3F-C3-29
LAN: 98-E7-F4-DB-71-74
(I changed my w-lan to primary in regedit and I’m connected to the internet via
w-lan also)
After trying everything like checking the license file, reinstalling CREO again - still nothing works. I even get an error filling in the license in the setup window so I used the earlier license file (with the right PATH and ID).
The license Is for the right HOST-ID, so it should work, but also the error says, that this license doesn't support this version (Creo Parametric 4.0 M060), but I can use the exact same version with the same license on my computer.
Can anyone please help me ?
1.]
34.0 in error message tells you that this is Creo 3.0 license.
2.]
BK400407EDSTUDENTUNICL belongs to Creo 3.0.
3.]
To install Creo 4.0 please follow http://apps.ptc.com/schools/references/install_creo4_unistudent_standard.pdf instructions.
