The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
hello guys,
ive just installed creo 7.0, but once i want to start creo parametric(or other programs) via the desktop shortcut, nothing happens and the file explorer opens. Can anyone help me?
best regards,
Jan
@JD_8823675 wrote:
ive noticed that there are some fields missing compared to creo simulate
@JD_8823675 wrote:
hello guys,
best regards,
Jan
copy shortcut from C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PTC directory.
hello, unfortunately **bleep** still doesnt work with parametric, simulate works fine. ive attached a video showing it.
check Properties of Creo Parametric 7.0.2.0 shortcut.
Thank you so much! It works perfectly fine now.
