I can find the stereoscopic configuration in the option menu, however, not in the bar menu, and unable to enable it!
The Solution described here wont work:
Stereoscopic 3D output - PTC Community
I have a quadro card stereo setup and other stereo applications works eg. catia v5.
Ok, it works with only creo view MCAD/ECAD license, mark solved.
please read https://www.ptc.com/en/support/article/CS346666
