i am using creo 2.0 student version. zoom option doesn't work in my computer when i use mouse. let me know how to fix this issue.
It sounds like you are on Windows 10, right? Creo 2 requires build M190 or greater for Windows 10, although I'm not certain how build numbers work with the student versions. There's also a solution posted here:
How to make scroll wheel zoom work in Windows 10 with Creo Parametric
There's an academic area of the community at the top, you might try to ask your question there. Toby Metcalf can also move this discussion for you.
Good morning Vishnu - I have moved this to Academic Support to get it the best views.
Thanks for alerting me Doug Schaefer
