Mathcad Prime: Export a string value to txt-file without quotes ""
To Define a string value in Prime 3.0, we need to use quotes """.
However when we export the value of the string to a txt-file, the txt-file will contain the quotes.
This functionality was already there in previous versions of Mathcad, but does not work any more in Prime.
1 Comment
Ruby IV
You may be interested in this thread: http://communities.ptc.com/message/233148#233148
The combination of str2vec() and WRITEBIN let you get rid of the double quotes.
The link I am referring to in the thread above is now useless as PTC has decided that this short fragment should be premium stuff and only available for the paying crowd, but the picture and the file I attached should be enough to get you up and running.
