Calculation of area under a curve through x,y data points
ptc-4266881
1-Newbie
I am using Mathcad Prime 7.0 7.0.0.0
I have a curve generated using a trace that connects plotted x,y points. How can I use Mathcad to calculated the area under that curve?
2 REPLIES 2
LucMeekes
(To:ptc-4266881)
Please attach the Prime worksheet. That will help us answer your question in the best way.
You should also know that this part of the Mathcad/Prime forum is mainly for installation questions.
Next time you should post here: https://community.ptc.com/t5/PTC-Mathcad/bd-p/PTCMathcad
LucMeekes
(To:LucMeekes)
This function calculates the area under the curve defined by x and y data.
It uses the triangle rule:
See attached Prime worksheet.
