Best Statistics software?
Level 4
Here we are, on the verge of 10.4, and still statistics software companies are asking if I have a 68k or PPC computer. Where can I get a decent statistics software package?
I'm used to using StatView - which no longer exists (and only works in os 9).
What I'd like is a stat package that does normal stats - like ANOVAS and the relevant post-hoc tests... And ideally easily modifiable plots (I hate having to cut and paste pictures of plots, and having labels be whatever the variable names are in the data file - please, dear god, let me edit it!)
Anyone?
Any help will be apprecited.
I didn't find the right solution from the Internet.
References:
https://arstechnica.com/civis/viewtopic.php?f=19&t=455879
App video company
Thank you.
1 REPLY
Re: Best Statistics software?
I recommend the free software "R"
https://www.r-project.org/
The R Project for Statistical Computing
Getting Started
R is a free software environment for statistical computing and graphics. It compiles and runs on a wide variety of UNIX platforms, Windows and MacOS.
Cheers
Terry
____________________________________ If you experience problems when attaching a Mathcad sheet file ( .mcd, .xmcd or .mcdx) to the message then zip it first. To get the .zip file, use Windows Explorer, select the sheet file, right-mouse click and select "Send to" then "Compressed (zipped) folder". This results in a .zip file containing the worksheet that you can attach
