Conditional Formatting
Level 7
How do you enter the equation below in mathcad prime 4.0
thanks for the help
Re: Conditional Formatting
1.
Do you have a full license of Prime, or are you using Prime Express 4?
(In Express you cannot enter programs).
2.
The function is a bit awkward. What is gmr ?
Who are x and y?
This is an example of how it might work, regardless of whether you have full Prime, or Prime Express:
How are you entering the x sub m
You can do it this way:
Call up the Matrix-index (Depends on the ORIGIN Variable which is in "calculations" defined)
Volker
so gmr is a number = 0.0171
what i am trying to do is this but in the prime edition, i am new to mathcadCapture.JPG
The simplest way to enter x sub m is by typing:
x [ m
Unless you happen to have the German language version of Prime where (according to Volker's picture) you'd have to type:
x <Ctl-Alt-[> m
where <Ctl-Alt-[> is pressing down the Ctrl key and the Alt key simultaneously and while they are down you hit the [ key once. Seems pretty much too cumbersome to me for such an often-used feature!
____________________________________ If you experience problems when attaching a Mathcad sheet file ( .mcd, .xmcd or .mcdx) to the message then zip it first. To get the .zip file, use Windows Explorer, select the sheet file, right-mouse click and select "Send to" then "Compressed (zipped) folder". This results in a .zip file containing the worksheet that you can attach
