Installation
- Error "1607 unable to install InstallShield scripting runtime" occurs when installing Mathcad 15.0.
- Error “1308: Source file not found …" occurs while installing Mathcad 15.0.
- Error “1904.Module \mcformsr.ocx failed to register. HREASULT -2147220473" followed by number of other DLL error occurs when installing Mathcad 15.0.
- Error “MDAC 2.6 SP2 contains a set of helper classes used by Mathcad..” keeps prompting while installing Mathcad 15.0 even after installing MDAC.
- Error “Microsoft Visual C++ Runtime Library, Runtime Error! Program: C:\Program Files\Mathcad \Mathcad 15\mathcad.exe. This application has requested the runtime to terminate in an unusual way” occurs when installing Mathcad 15.0.
- Platform Support and System Requirements for Mathcad 15.0.
Miscellaneous
- *Frequently Asked Questions - Installation
- *Frequently Asked Questions - Licensing
- Activation Troubleshooting - Error “You have reached the maximum number of license files available for your license type” while retrieving Mathcad license via Internet.
- Activation Troubleshooting - Error: "401: Unauthorized User".
- Activation Troubleshooting - Error: "407: proxy authentication required”.
- Activation Troubleshooting - Error: "503 Error: Server Unavailable”.
- Launching Mathcad 15.0 yields error "Mathcad application has stopped working".
- Launching Mathcad 15.0 yields error "Terminal server remote client not allowed", “FLEXnet Licensing error:-103, 577”.
- Launching Mathcad 15.0 yields error “Failed to Launch Server Application”.
- Launching Mathcad 15.0 yields error “Future license file format or misspelling in License file”, “FLEXnet Licensing error: -90, 313”.
- Launching Mathcad 15.0 yields error “Invalid Host. The hostid of the system does not match the hostid specified in the license, FLEXnet Licensing error: -9, 57”.
- Launching Mathcad 15.0 yields error “Library not registered".
- Launching Mathcad 15.0 yields error “Microsoft Visual C++ Runtime Library, Runtime Error! Program: C:\Program Files\Mathcad\Mathcad 15\mathcad.exe. This application has requested the runtime to terminate in an unusual way".
- Launching Mathcad 15.0 yields “Unable to Create 12.0 Engine Factory” error.
- Mathcad Engineering Libraries are not displayed under #Help > #E-Books after upgrading to Mathcad 15.0 from Mathcad 14.0.
- Mathcad displays specific Greek symbols as a square box.
- Mathcad does not display the 3D Plots on Windows Vista/Windows 7 Operating System.
- Mathcad does not launch when disconnected from network or from laptop docking station and reports an error “Invalid Host. The hostid of this system does not match the hostid specified in the license file."
