One MPEI-Linkage (mechanical) - help please
Level 17
I would like to create Linkage wich end point writes this: МЭИ - see please the picture!
See one animation and attached Mathcad 15 sheet as a start point of this work!
Thanks for links and etc!
See more https://community.ptc.com/t5/PTC-Mathcad-Questions/Chebyshev-Math-Journey/m-p/536496
1 REPLY
Re: One MPEI-Linkage (mechanical) - help please
May be it is new art form! What can you say?
____________________________________ If you experience problems when attaching a Mathcad sheet file ( .mcd, .xmcd or .mcdx) to the message then zip it first. To get the .zip file, use Windows Explorer, select the sheet file, right-mouse click and select "Send to" then "Compressed (zipped) folder". This results in a .zip file containing the worksheet that you can attach
